PonyXpress
- Joined
- Jan 11, 2008
- Messages
- 9
- Reaction score
- 0
90 bronco no power to pump. wife was driving the thing when it quit. there was a bump in the road and when she went over it the vehicle was jarred and just quit. turn the key and it doesn't even make noise. checked inertia switch first. it was not tripped, , looked like the connector got hot. replaced a perfectly good fuel pump. replaced a fuel pump relay. low voltage to inertia switch. used code reader, got a pcm code and a pcm ground code. had pcm reconditioned, replaced fuel inertia switch, and its melted connector, new battery, battery connections tight and clean, turned the key and nothing happened. code reader still says pcm ground. have crawled all over looking for bad ground connections. can not find it. been down for over six months. any suggestions will be greatly appreciated as long as some a--hole doesn't say buy a chevy.
