1987moneypit
my 1987 bronco (5.0)302 4x4 is slipping in 1st gear between 1700 and 2400 rpm's and then will shift to 2nd. i have changd the filter, modulator,used lucas additive and sea foam. when i changed the fluid out, there was a sludge in the pan(not metal shavings) is there a linkage that i can adjust, or a vacuum besides the modulator? any suggestions will be helpful. thank you
