Question about my idle
sbveenker
So i have a 94 5.8l and when its just sitting there it will idle about 6000-7000 about normal then it will like drop then come back up and continue to do this. It runs fine while your driving and it never drops enough to die. Anyone have ideas
madmax
quakertown pa
Ill assume you mean 600 to 700 rpms, 6 or 7 thousand would cause valve floating or possibly break a rocker arm.
try cleaning your idle air control valve, also is your ac on when it does this? how big is the drop? does it drop down to 500 or 200? another thing that can cause this is a problem with the EGR valve causing it to smother the engine with too much exhaust.
Burns
Royersford, PA
Yea, my engine was hunting for it's idle when I first got it. Carb cleaner and the idle air controller and also cleaned the throttle body. After that, the idle was steady as could be.
Burns
Royersford, PA
Where is the idle control valve located?
On a 5.8, I'm not 100% sure, but it should be like a 5.0. Where your air intake meets your throttle body, on the side of the throttle body should be a cylinder-like device, laying down, about 6-7 inches long. That's your idle air control. It's 2 bolts that hold it to the throttle body, and be careful not to lose the gasket there. It's a tight fit for the bolts.
Hopefully this helps.
yo!
Do you have a check eng. light lit?
if so, should do a scan or self test
Self Test & Connector Location & pics, Bronco & Ford BEST PROCESS WITH DIAGRAMS! Source: by Ryan M
& then post results here;
for now on da IAC:
Sensor, Idle Air Control (IAC) Cleaning in a 93 5.8 Source: by Bobby (blue)
Sensor, Idle Air Control (IAC), Idle or Noise Problems & Troubleshooting Source: by Joe D at carquest.com via web.archive.org
"Ford vehicles with an Idle Air Control
Motor (called IAC) that have idle
problems and sometimes noise concerns
can be diagnosed in the following
manner. For high idle problems, try
unplugging the IAC motor. If the idle
drops, its usually due to an input signal
to the computer which results in the
computer raising the idle speed. If this is
the case, look at all of the computer
inputs to make sure everything is up to
par. If the engine RPM does not drop
when the IAC motor is disconnected,
then either the IAC motor is not
functioning properly, or, there is a
vacuum leak in the engine. Stop the
engine, remove the IAC motor and block
off the passages. Restart the engine to
see if there is any change in engine
RPM. An idle speed higher than base
idle specs indicates a vacuum leak. If the
engine RPM is at base idle specs, then
the IAC motor is bad. Resistance specs
are 7-13 ohms. A good resistance reading
does not necessarily mean that the
IAC motor is good. Occasionally, an
IAC motor will become weak, and will
actually bypass too much air, causing a
high idle condition even though
everything else is operating properly.
Diagnosing an IAC motor and its
circuit is fairly easy. This motor uses a
two wire connector...
read more in his article..
or. other possibilites;
DTC Codes 122 through 125 Troubleshooting & Possible Causes; The Throttle Position Sensor (TPS) is located at the end of the throttle shaft on the throttle body. Using the TPS voltage signal the EEC determines fuel delivery based on throttle position. A bad TPS can be the cause of bad idle, which is caused by the injector pulse fluctuating. Some loss in performance can also be expected.
GL!
tsebalj
