I have a 93 Ford Bronco that is all stock and rides alot harsher than I think it should. The trim screws inside are falling out due to the jolts from normal driving around town. I have put shocks on from Midas and the tires are stock size, Michelins with 32lbs of air in them. I had a 4W/D shop check the body mounts and they said everything was tight. Any suggestions on why I would get such hard jolts over small bumps in the road? The Bronco has 177,000 miles on it. My son and I are going to use this Bronco as a project truck in about a year. Thanks!!
