Transmission I.D. Chart
Status
Not open for further replies.
Mike @ Tracy
winnemucca nevada
I.D. CODE DEFINED
B (1976-78)- Warner T-85 3speed
C- Ford-Manual 3speed
D- Warner T-89 3speed
E- Warner T-87 3speed
F- Warner T-18 4speed
A (1976-86)- New Process 435 4speed
P- Warner T-19 4speed
B (1979-86)- Clark 4speed O.D.
G- Automatic C4
W- Automatic C5
P- Automatic C6 thru 1977
K- Automatic C6 1978-86
J- Automatic FMX
T- Automatic Overdrive
This list is for 1976-86 Fullsize Broncos and F-100 thru F-350. This includes 2 and 4 wheel drive. It also covers gas and diesel engines. These trans codes are usually found on the driverside B pillar and are also on the transmission I.D. tag attached to the trans itself.
Here's some additional info:
Model: C6
Type: three speed non-electronic
Years:
'66-'90 F-series
'78-'89 Bronco
'91-'96 ('97?) F-2/3/superduty
Engines:{300, 302, 351w}, {400, 351m, 460}, {6.9L, 7.3L IDI}, {352, 360, 390, ect.}
Fluid:
Pre '77: Type F
Post '77: Mercon
Display: PRND21
Pan 17 bolts "Utah" shape
Ratios:
1st 2.46:1
2nd 1.46:1
3rd 1.00:1
Trans code: K
Model: E4OD
Type: Electronic Four speed Over Drive
Years:
'90-'96 Bronco,
'89-'98 F-Series
Engines: {300, 302, 351w}, {460}, {7.3L IDI}, {7.3L PSD}, {5.4L}
Display: PRN(D)21 w/ overdrive lockout switch
Pan: 20 bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E
Model: AOD
Type: Four speed non-electronic
Years:
'85-'93 F-150
'85-'89 Bronco
Engines: 302
Display: PRN(D)D1
Pan square with small ****
Fluid: Mercon
Ratios:
1st 2.40:1
2nd 1.47:1
3rd 1.00:1
4th 0.67:1
Trans code: T
Manuals
Model: M5OD-R2
Type: Five speed Mazda Overdrive
Years: 88-96 Bronco, F150s
..........97-03 F150s
..........05 F150 (v6)
Engines: 300, 302, 4.2L, 4.6L
Fluid: Mercon
Display:
1.3.(D)
2.4.R
Ratios:
1st 3.90:1
2nd 2.25:1
3rd 1.46:1
4th 1.00:1
5th 0.80:1
Construction features: External Ribs in square patterns
Trans code: M
Model: SROD
Type: Four speed overdrive w/ push down reverse
Years: 80-83(4?)
Engines: 300, 302
Fluid: ?
Display:
P..R..1..3
U
S.....2..OD
H
Ratios:
1st 3.25:1
2nd 1.92:1
3rd 1.00:1
4th 0.78:1
Reverse 3.25:1
Construction features: Aluminum, shifter near back
Trans code: B
Model: NP-435
Type: Four speed non overdrive
Years: 80-87?
Engines: 300, 302, Your mostly gonna find it behind a 300.
Display:
1.2
3.4.R
Construction features: Cast Iron w/aluminum top plate, shifter in top, PTO Pass side
Fluid: 140w
Ratios:
1st 6.69:1
2nd 3.34:1
3rd 1.79:1
4th 1.00:1
Reverse 3.25:1
Trans code: A
Model: T18
Type: Four speed, non overdrive, non syncro first gear
Years: ?
Engines: 300, 302, 351, 460
Fluid: ?
Display:
1.3
2.4.R
Construction features: Cast iron throughout
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code: F or P
Model: T19
Type: Four speed, non overdrive, syncro first gear
Years: ?
Engines:460?, 6.9L, 7.3L
Fluid: ?
Display:
1.3
2.4.R
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code F or P
Model: ZF5
Type: Five speed heavyduty overdrive
Years: 87-99 F2/3/450/superduty
Engines: 300, 351, 460, 7.3
Fluid: Mercon
Display:
1.3.(D)
2.4.R
Ratios:
S5-42 (Diesel)
1st: 4.14
2nd: 2.37
3rd: 1.42
4th: 1.00
5th: 0.77
Reverse: 3.79
S5-47 (diesel)
1st: 5.08
2nd: 2.61
3rd: 1.53
4th: 1.00
5th: 0.77
Reverse: 4.66
S5-42 and S5-47 (gas)
1st: 5.72
2nd: 2.94
3rd: 1.61
4th: 1.00
5th: 0.76
Reverse: 5.24
Trans code: 2
Photo links:
Novak Enterprises - http://www.novak-adapt.com/knowledge/trans...ion_gateway.htm
Motive Gear - http://www.motivegear.com/tech_info/tranny...anny_guide.html
Drivetrain.com - http://www.drivetrain.com/transmanualrebuildkit.html#FORD TRUCKS & VANS
Tranny tag ID chart - http://www.alldrivelineparts.com/transmissions/atfdbron.html
●Auto tranny pan ID and pics @ http://www.badshoeproductions.com/trans.html
SM84
The 73'-77' Broncos used the C4 & the Bronco II's used C5's (just a C4 with a lockup TC). It's also in my 78' shop manuals with the F100 & F150 being listed as applications. I know F-trucks used C4's up till 82 or 83 but I don't think any of the big Broncos ever had one.
Status
Similar threads
Utahstroke
