Ford Bronco Zone Early Bronco Classic FullSize Broncos: Sag pump install - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • This topic is locked
Sag pump install 96 Bronco
#1 User is offline   boss
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
Posted 17 March 2007 - 09:19 AM
For more flow and better performance, you can't beat a sag.
The old pump
Posted Image
remove the intake hose for more room
Posted Image
remove fan belt
Posted Image
I have a hydroboost on my bronco thus the braided lines
Posted Image
remover the 4 bolts holding the AC pump in place
Posted Image
I used a strap to hold it up out of the way, take care not to bend the ac lines
Posted Image
Remove the bolts that hold the pump and bracket in place
Posted Image
Heres my old pump in front of 3 sags, couple are off of 351 engines and one is from a 5.0, regardless the brackets are all the same
Posted Image
Posted Image
add the adapter I need for my braided fittings
Posted Image
Heres the hole with the pump and bracket removed
http://www.supermotors.net/getfile/496219/fullsize/dsc01921.jpg
dropping the sag in place
http://www.supermotors.net/getfile/496220/fullsize/dsc01923.jpg
bolt the ac pump on
http://www.supermotors.net/getfile/496221/fullsize/dsc01924.jpg
looks like it belongs
http://www.supermotors.net/getfile/496222/fullsize/dsc01925.jpg
stock belt fits
http://www.supermotors.net/getfile/496223/fullsize/dsc01926.jpg
need to make a longer line
http://www.supermotors.net/getfile/496224/fullsize/dsc01927.jpg
http://www.supermotors.net/getfile/496225/fullsize/dsc01928.jpg
http://www.supermotors.net/getfile/496226/fullsize/dsc01929.jpg
http://www.supermotors.net/getfile/496227/fullsize/dsc01930.jpg
http://www.supermotors.net/getfile/496228/fullsize/dsc01931.jpg
pic of the hydro boost from a f450
http://www.supermotors.net/getfile/496229/fullsize/dsc01932.jpg
finish off with the install of the intake hose
http://www.supermotors.net/getfile/496230/fullsize/dsc01933.jpg
http://www.supermotors.net/getfile/496231/fullsize/dsc01934.jpg
little tight to get the cap off
http://www.supermotors.net/getfile/496232/fullsize/dsc01935.jpg
thats it, fill it up and bleed - proper way to do is is by disconnecting your drag link and cycle the wheel back and forth - no whining.
:D more of my bronco here http://www.4x4preser...isplay.php?f=23
This post has been edited by boss: 17 March 2007 - 09:21 AM
-Steve
4x4preservation.com
Page 1 of 1
