QUOTE (rebel33382 @ Nov 13 2008, 01:13 PM)
Any Ideas, I battled and won code 332 (which throws a CEL) about 2 months ago. Now I decided to pull codes and got the 334 code, and its driving me crazy. I have replaced EVR, EVP, and a fairly new EGR. !!!
Thanks in Advance
Code 334 DPFE or EVP circuit above the closed limit of 0.67 volts.
I am just guessing that it would range from 0.67 volts closed to 5.0 volts fully open. I may be completely wrong.
IF that's the case, could a bad ground cause a higher than normal voltage? Teh problem is, I can't tell which is the ground for it.
In addition, did you check to make sure that the vacuum line comeing from the throttle body is not clogged?
Your coolent level is topped off, right?
