QUOTE (Grey2003 @ Nov 26 2008, 02:50 PM)
Took the headliner out and there is no wiring harness sitting there. I even put a 1" whole saw up there to feel around and got nothing. I wouldn't think it would be between the headliner and the inner roof panel though at that would be a potential rattle and the existing map lights wiring also goes in between the outer roof and inner panel. After a bit I did find the receiver for the harness behind the emergency brake, but nothing was connected to it. So I guess that I don't have the wiring in the roof, sooo does anyone have the correct wiring for receptacle behind the emergency brake. I have looked and looked and no one has a diagram for it. only for the harness itself and from all the wires in the harness, there appears to be some different colored ones to hook up to.
That sucks, I don't think I'll be getting back to my local friendly junk yard for a while, but if I do, I will check the harness for an Explorer to see if it is the same. You could probably order it from Ford, most likely expensive though. Another option is to get the plugs and make your own. Like I said, I have an extra plug that goes at the console end. Is it possible to get a picture of the one under the dash?
For my truck I have to build the whole thing all the way to the sensor.
