3gunshooter
Nov 6 2008, 09:38 AM
I replaced the fuel pump truck wont start now checked fuses they look good and checked if the fuel pump relay was tripped its not. I can not here the fuel pump turn on. Next problem ford has the stupid disconnect on there fuel lines The line that goes from the fuel filter to the fuel pump is messed up the little metal pieces in the quick disconnect pulled out on both sides. Went to a Ford Dealer today they said that the lines have been discontinued. Besides going to a junk yard anybody know where I can find them Just spent gobs of money to redo the motor and got a truck that cant move.
BroncoJoe19
Nov 6 2008, 12:00 PM
Sorry ... can't help with the disconnect, but did you check your inertia switch (fuel pump safety shut off) on the driver's side firewall under the dash?
3gunshooter
Nov 6 2008, 12:48 PM
QUOTE (BroncoJoe19 @ Nov 6 2008, 03:00 PM)
Yeah It did not get tripped
Nov 6 2008, 01:39 PM
Thats the enertia switch, the relay is a different component altogether. it is under your hood. they go all the time, I would check that
Ogeechee 4x4
Nov 6 2008, 02:08 PM
If you can't hear the fuel pump run, I'd double check your electrical connections
BroncoJoe19
Nov 6 2008, 05:40 PM
How to test your fuel pump relayThe fuel pump relay (at least on a '90) is on the driver's side by the wheel well, under a black plastic protector.
bronco410w
Nov 6 2008, 07:36 PM
isnt there any way to bypass it? possibly?
BroncoJoe19
Nov 7 2008, 02:20 AM
they're inexpensive, I think less than $15
3gunshooter
Nov 7 2008, 05:50 AM
appreciate I work Till Tuesday morning will have to check it then and let you guys know
wilsbronco
Nov 9 2008, 03:23 PM
QUOTE (3gunshooter @ Nov 6 2008, 11:38 AM)
Do you mean the stupid metal ring-with-fingers things that goes inside the connection? I had to go to 3 flaps, but I finally found them at advance auto (my bronco doesn't use them, thank goodness, but my sisters explorer does)
3gunshooter
Nov 13 2008, 12:38 PM
QUOTE (wilsbronco @ Nov 9 2008, 06:23 PM)
Yeah thats it. Advance has them? do you know what they cost byany chance cause I would rather buy a new one then build my own
bigtrux
Nov 14 2008, 06:48 AM
I would check the electrical connection like Ogeechee said i had the same problem and every now and again i have to mess with it the one on right before the tank to the pump .
3gunshooter
Nov 16 2008, 12:18 PM
Problem fixed. After cutting a hole in the bed so I did not have to drop the tank again, Me and a friend tested the butt connecters it was a bad connection between the sending unit and pump.
wilsbronco
Dec 14 2008, 08:10 AM
I assume you probably found them at Advance. As I recall, the package was under $5 for I think 3 or 4 of them. Hanging down one of the rows with all the miscellaneous connector type parts.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
