QUOTE (mustang_man96 @ Oct 26 2008, 07:05 PM)
FOR SALE 1993 Bronco Sport XLT Strong Running 302 Automatic. Clean interior with no rips or tears, motor does NOT smoke or knock. Trans shifts good, and steady. Dark Blue with blue interior. 171,000 Miles. Usual rust over rear wheel wells, and on tailgate. Dash is perfect and has aftermarket AM/FM CD player that sounds great! Needs tailgate glass, front brake rotors and pads. 4 wheel drive will not engage. Will need tires soon, but will get you through. Everything works like it should, has manual windows and tilt wheel. Cruise works great. It is the same truck in avatar. Have clean and clear title in hand. Asking $1500. Call me at 859-743-0416, or email at fordsrus@blueone.net Thanks!
MM, I still think your crazy. $1000.00 is too little. I have the rear window parts and if this one has the push button 4x4, I also have the transfercase motor you need to engage the 4x4. That is an ez fix and could also be a fuse or switch problem. Not to mention vacuum. --Vince
