Help - Search - Members - Calendar
Full Version: lift question
Ford Bronco Zone Forums > Technical Support > 80-96 Ford Bronco Tech Support
the green monster
Alright, I have a 1994 bronco xlt with ttb. i have 4 inch lift blocks in back and am getting a 3 inch body lift. but im sick of the racecar look and want to lift the front four inches too but im poor so if i buy four inch lift coil springs up front. what other stuff would i have to buy to make the lift work?
Roadkill
In addition to the springs, you will need axle pivot brackets with 4" drop, radius arm brackets with 4" drop, and a drop pitman arm.
White 5speed 5.0
^^^ And shocks. But wait, you have 4" blocks in the rear and nothing in the front???? Thats a little intense. To be honest i was looking into doing the same thing, well a custom suspension set up, but quickly found out that thats not the best option on TTB trucks. Each manufacturer of these lift kits has slightly different specifications on their lift kits, so everything probably won't work out that well. Plus, if you try and buy things seperately it winds up costing more then a straight up kit in the long run anyway. To get rid of the blocks in the rear, a decently cheap set up is using the shackle flip, which is kind of labor intensive, but honestly easy to figure out.
the green monster
QUOTE (White 5speed 5.0 @ Oct 15 2008, 07:48 PM) *
yeah, i have 4 inch lift in rear and none in front, it was cool for awhile but not so much right now. and i want it to be high but in cant afford a lift. do you have any information on how to do a shackle reversal? any help would be greatly appreciated!
check out sky manufacturing. They have a nice shackle flip kit for cheap
Miss Kitten
if you have welding abilities i can get pictures of my shackle flip that we did with the stock shackles if you'd like
the green monster
QUOTE (Miss Kitten @ Oct 16 2008, 03:18 PM) *
I can weld so those pics would be great! how much lift would that give?
You can expect about 4.5 inches in the rear from a shackle flip.
Miss Kitten
i'll try and get those pics today for you. if not i'm gone for a work trip for the week. so be patient smile.gif
bluesman17
keep in mind that when they are talking about the shackle flip that is for the REAR, they do sell levelers (like 2 inches) that im pretty sure the front springs just rest on that may be able to help you sit a little higher up front..
bronco410w
QUOTE (bluesman17 @ Oct 17 2008, 01:12 PM) *
daystar makes them... there around $100.00 gives yah 2 inches up front!
bluesman17
daystar front helpers:
http://www.suspensionconnection.com/cgi-bi...KF09108F1L.html
stusainte
Just a word of advice if your going to do this be carful of mismatched parts and not a mickey mouse job cheap is not allways the best way!! but most of all do it right Just my opinion good luck
the green monster
thanks guys. im getting those levelers, taking out the blocks and doing the shackle flip. i'll post pics when im done!
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
