302 CID 3 SPEED ON COLUMN
76875 ORIGINAL FRAME MILES 3700+ ENGINE MILES
3 1/2" JEFFS BRONCO GRAVEYARD LIFT KIT
SUPERFLEX LONG TRAVEL RADIUS ARMS
31X10.5 RT 15 BF GOODRICH LAND TERRAIN TIRES 85% FULL SIZE SPARE 50%
PROGRESSIVE REAR HUB AND ALUMINUM RIMS ALL AROUND
WARN FRONT LOCKING HUBS
23 GALLON NORTH WESTERN GAS TANK
EDELBROCK PERFORMER ALUMINUM HEADS
EDELBROCK PERFORMER CARB CAM AND 600 CFM INTAKE MANIFOLD
CRANE ROLLER ROCKERS AND DOUBLE-ROLLER TIMING CHAIN
D.U.I DAVIS UNIFIED IGNITION DISTRIBUTOR
4 CORE ALUMINUM RADIATOR
JBA NICKEL SHORTY HEADERS
MANDREL-BENT 2 1/2 " FLOWMASTERS
HYDROBOOST FRONT DISK BREAK SYSTEM
NEW ELECTRIC WIPER MOTOR WASHER FLUID PUMP LINES etc.
WALNUT GRANT STEERING WHEEL STAINLESS DOOR PANELS NEW ARM REST
LOTS OF NEW CHROME REARVIEW MIRROR SIDE MIRROR EMBLEMS REAR LATCH HANDEL etc.
NEW RUBBER WINDOW SEALS AND GASKETS
ARIZONA AIR AIR CONDITIONING SYSTEM
PYLE MARINE STEREO CD #15 SYSTEM
PYLE 1000 WATT 4CH AMPLIFIER
PYLE 300 WATT SPEAKERS X2
MOTION SOUND SENSORY ALARM SYSTEM
REMOTE KEYLESS ENTRY
PAINLESS WIRING KIT INSTALLED
MOST OF THIS WORK HAS BEEN COMPLETED WITH IN THE PAST 3 YEARS.
THERE IS MUCH MORE NOT LISTED HERE.
I AM WILLING TO HELP COORDINATE SHIPPING AND WILL ALLOW YOU TO HAVE AN INSPECTION
THIS IS ONE OF TWO DAILY DRIVERS I TAKE TO WORK, 2 MILES AWAY.
I HAVE ALL RECEIPTS TOTALLING OVER $17,750 NOT INCLUDING HOURS AND HOURS OF LABOR.
EVERYTHING INSIDE & OUTSIDE RUNS WORKS LOOKS SOUNDS EXCELENT!!!
WIFE AND I ARE BUYING A HOME HERE IN THE KEYS AND NEED EVERY PENNY.....SOME OF THE TOYS
MUST GO.
