Driver and Passenger Power Window
Status
Not open for further replies.
If you decide that you need to remove the Driver side or Passenger side power window motor, here is the proceedure.
Removal
1. Disconnect the battery ground cable.
2. Remove door trim panel.
3. Disconnect power window motor wire from wire harness connector.
4. Check inside the door to make sure that the electrical wires are not in line with holes to be drilled in the door inner panel. Using a 1/2 inch diameter drill bit drill two holes in the door inner panel at the drill dimples located opposite the two unexposed motor retainer screws.
5. Remove the three motor mount retainer screws using the two drilled holes and existing large hole access to ***** heads.
6. Push the motor toward the outside sheet metal to disengage the motor and drive from the regulator gear. After the motor and drive are disengaged prop the window to full UP position.
7. Remove the motor and drive from inside the door.
Installation
1. Install new motor and drive assembly and tighten retaining screws to 85 in. lb.
2. Reconnect the power window motor wiring and battery ground cable.
3. Remove glass prop and check window operation.
4. cover the drilled holes with two pieces of body tape 1" square, I use metalized duct tape for this kind of thing :-"
Status
eholt80
