91 bronco only starts with spray start.
john-mona-vie
miami fl.
engine only starts with spray start,then runs extemely rich. new fuel pump & fuel pressure regulator installed. 38 psi at fuel rail, system cleaned w/ injector cleaner. any ideas
Krafty
Ontario Canada
is it possible that the air fuel mixture is off so much that it could be causing your problem? look at coolant temp sensor and o2 sensor to start. and check for codes.
npsurf1
