Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> Dana 44 and Ford 9", Matching gears
Wild Willy
post Nov 2 2009, 05:50 PM
Post #1
Bronco Newbie
Group: Members
I am working on a frame off restoration project. I have a 66 that has the 170 six cylinder in it. I bought a 70 Bronco Sport that had been rolled (lightly) for parts that has the 302. The 70 runs good but is a rust bucket. I have also obtained many other parts from a 73. I want to install the Dana 44 from the 73 on the frame of the 70 along with the 9" from that same Bronco. I will then take the body from the 66 and put it on the 70 frame. Here is my question: The 9" has a tag number WEM-E 9KB 3.50 8.7 605A and the Dana 44 has a tag number of 3.54 D3TA-KA 603368-3. Will these two gear combonations work together or do I need to match them? Where can I find more information on how to set up the differentials? I am clueless on this part of the build.
Go to the top of the page
+Quote Post
post Nov 2 2009, 06:50 PM
Post #2
Supreme Commander
Group: Members
Hay Wild W....,
I doubt that's a prob. but research it a bit more. (4:10's & 4:11's are often seen together)
---BUT ---
I wouldn't trust the tags.....
Mark the wheel and the pumpkin yoke...one revolution of the wheel should net you 3 1/2 turns of the yoke.
As I recall.., the other wheel needs to be on the ground., so as not to turn., to get a correct reading.
I would use which-ever 9" that has the large bearing....if in fact., one does.
HTH
BTW.., What are you going to do with the 170 c.u. I-6 ?
This post has been edited by Bully Bob: Nov 2 2009, 08:48 PM
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Pwr. steering, Hurst 3-speed floor shifter.
Split headers, dual exhaust, Holley 1 brl.
Stock axles...456's...32's ...Posi rear. 2.5 in. lift.
Full roll-cage, front.
65 gallons of fuel on board..!
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
+Quote Post
BUCKIN67
post Nov 3 2009, 05:43 AM
Post #3
Where's My Hammer!?!
Group: Members
QUOTE (Wild Willy @ Nov 2 2009, 08:50 PM) *
Hi there Folk's, my name is Dusty. I am a ford motor co. senior master tech with 23 years as a mechanic with ford. I am also a ASE master with L-1 advanced level cert. I have been broncoing for years!! I own a 1967 bronco wagon, up graded to a 200 cid six, P/S, power brakes. We have been through the inside and out. I will post a pic later on. Im new here so bare with me!
+Quote Post
BUCKIN67
post Nov 3 2009, 05:51 AM
Post #4
Group: Members
Hi there, I am sure that 3.54 (dana) and 3.50 (ford) are the same combo. The difference is dana and ford manuf. I would always suggest counting the teeth on the pinon and the ring gear and dividing the pinion into the ring # for ratio ID. I am certian if you had gotter them out of the 70 then they match and work together already obviously. If your putting the 66 body on the 70 frame isnt the diffs already in the 70 chassis? Also the 66 prob had a 4.10 and 4.11 combo for the tiny 170 eng. Id bet. You can look up my profile on here, Im a FORD motor co senior master technician and ASE master, have been a mechanic for 23 years and broncoing for bout 18. Yep, bully bob is also right bout that large bearing, the difference is 2800 lb or 3300 lb rear axle. The larger is much stronger and is easily identified by the size of the outer housing near the backing plates. just look where the leaf spring are bolted on and see how small it drops down to. I hope this helps ya some! GOD BLESS YA!!
+Quote Post
Wild Willy
post Nov 3 2009, 06:17 PM
Post #5
Bronco Newbie
Group: Members
Thanks everyone for the helpful info.
+Quote Post
riggermortis
post Nov 13 2009, 04:55 PM
Post #6
It's Only Money, Right?
Group: Members
anybody correct me if im wrong, but isnt the front sopposed to be just a little higher geared than the back so that it pulls just slightly, and thats why you cant drive on a hard surface or it will bind. right???
1967 sport bronco 302 w/efi, 1992 F250 7.5L, 2001 cobra mustang 32V 4.6, 1979 harley FXS lowrider 1340
+Quote Post
post Nov 13 2009, 05:05 PM
Post #7
Supreme Commander
Group: Members
Hay rig...,
Yes & no ....... the factory doesn't do this 'but' competition rigs do as it does help. (i.e. higher in the front)
I doubt the factory recommends 4x4'n on pavement even with equal gearing F&R....at least on the older rigs.
+Quote Post
S_bolt19
post Nov 13 2009, 10:56 PM
Post #8
Bronco Commander
Group: Members
typical rule of thumb is that if you are within 2-5% of each axle, you are good. A 4.11/4.10 combo is within less than .3% where a 3.50/3.54 is about 1.14%. Either way you are still fine. Now if you run a 3.50/4.10 combo (about 17% difference), you will see where it will trash just about everything connected to it.
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
+Quote Post
Fast ReplyReply to this topicStart new topic
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
Lo-Fi Version Time is now: 20th November 2009 - 04:22 PM
