jsomedaysoon
the piece that holds the y pipe to the manifold on my 84 rusted out and fell apart on me creating a massive exhaust leak. i tried to fix it but i think i made it worse. i cut the pipe at its lowest point where it comes across to the drivers side and slipped on a new part. but when i tried to get the old bolts out they both snapped off. Am i totally screwed at this point or is there some way to recover before i have to admit defeat and take it to a pro. i've never used a tap and die set before is this something that would work on? Also there is some part in there that i've never seen before. it slips in between the manifold and the y pipe. Lmc truck is calling it a "heat riser" http://www.lmctruck.com/ICATALOG/FD/full.aspx?Page=105 if i did that right it should be the link to it. Any clue what its for? or if its important? it has a lever that can open and close a flap inside the pipe.
